WD engines
Kevin
09-17-2001 11:30:14
Can anyone tell me the difference between engine numbers that end with PA verses GA. I was just curious. Thanks, Kevin
Brian G. NY
09-20-2001 06:50:51
 Re: WD engines in reply to Kevin, 09-17-2001 11:30:14
I think they are the same; designed to burn gasoline. A-C apparently changed the Engine Serial # suffix sometime in '50 or '51. I have a '50 WD with the GA suffix and a '51 with the PA suffix, both designed for Gasoline. My WD-45s use a G suffix. K or KA was the designation for Kerosene or "tractor fuel". I believe these engines had a lower compression ratio; I assume attained by use of different pistons. According to the manuals, the compression ratios for WDs Gas: 5.75 to 1 Fuel: 4.1 to 1 WD-45s Gas: 6.5 to 1 Fuel: 4.75 to 1
