What loaders fit WD
Greg
09-16-2001 03:39:34
Hi, I want to find a used loader for my 1950 WD. I would like some ideas on what kind and models. Thanks
Simon
09-23-2001 08:11:56
 Re: what loaders fit WD in reply to Greg, 09-16-2001 03:39:34
I have NI loader w/large bucket,good paint if interested. where do u live?
steve Schainost
09-17-2001 10:55:06
I have a trip-bucket Farmhand F-15 on my WD-45. My dad has a DuAl on his WD. The DuAl has ability to operate three hydraulic cylinders so uses a hydraulic pump on the PTO. I agree with acd17toy in that most of the older loaders can be modified to fit. Just need to make sure there is clearance front to back and will fit the rear axle. The bracket to the frame can be modified or a new one made fairly easily.
Bob
09-17-2001 08:30:45
I have a Paulson loader, Trip type on mine, after using hydralics its sort of back in time, and dont dig to well, but its ok. Paulson makes new ones that are hyd. so you may contact them in Rogers MN. They have a web site, just go paulson loaders on the search you should find it. Dual is good, just watch the weight of the loader, the front end is already tired and no power steering. Some of the older ones may be hard to get parts for. Bob
ORNGBOY
09-16-2001 15:20:24
I have an Allis WD9 trip loader on my 1951 WD. Have plans to make it ALL hydraulic in the future. There are DUAL loaders that fit, too. Don't know which ones right off hand. I'm sure there are some AC fellas in here that know for sure. Good Luck.
acd17toy
09-16-2001 06:38:53
greg most of the older loaders will fit the ac's.Freeman and new idea and AC were poplur for the wd and wd45. when you find one make sure that it will fit on your tractor without making costly changes on the mounting brackets
Terry
09-16-2001 15:01:47
 Re: Re: what loaders fit WD in reply to acd17toy, 09-16-2001 06:38:53
Greg, My WD45 has a Dual loader on it. It is mounted to the rear axle with a clamp-type apparatus. Braces to the frame hold the uprights in position.
