Power steering diagram for WD or WD45
Plow Man
09-15-2001 19:22:27
I was wondering if anyone had a diagram for setting up a power steering unit on a WD. I was told it is possible to have a unit from a D-17. How does it all hook up? I mean the pump and the motor I know were those are. But is there a resevivor or valve system? If anyone has a WD or a WD45 with a PS unit setup could you help me with my problem. Thanks.
Dave Grubb
09-17-2001 06:58:20
 Re: Power steering diagram for WD or WD45 in reply to Plow Man, 09-15-2001 19:22:27
Go to the 'search this site' area and type in power steering for the AC line. There are over 200 items on this subject. A guy named Dana Hobson has some pictures posted of his power steering on a WD45. I am working at installing power steering on my WD45, but have stopped for harvest and I am still mowing with the tractor. I am using a Char-Lynn unit spliced into the steering shaft near the starter area. My pump is a Ford unit with the integral reservior mounted at the old generator mount area. This allows the fluid to be checked without removing anything and eliminates a seperate reservoir. The air from the fan helps to keep the fluid cooled down. I am mounting the alternator above the cylinder head/water pump area. The alternator rarely needs attention so I thought this would be a good place for it. Genesee Products has some really good alternator mounting blocks and slotted adjusting brackets. You have to get a dual groove crankshaft pulley and several parts folks on this site offer them. The pulley comes off the crankshaft very easily. The Char-Lynn unit is the hard part to get. You can buy a new one from Force America(1-800-3282732).The new units have changed in design a little and may not fit a WD I am told, although the salesman was not sure. To find a used unit is just a 'beat the bushes' operation and takes time. Hope this helps.
