WD 45 REAR WHEEL?
Shane
09-13-2001 09:49:17
I AM LOOKING FOR A 12-28 WD 45 REAR WHEEL. I AM CONSIDERING PURCHASING WD-45 WITH A REAR WHEEL THAT HAS A HOLE IN IT. WHAT WILL THIS WHEEL COST?
ALSO WHAT IS THIS TRACTOR WORTH? WD-45 RUNS DECENT, NICE HOMEMADE 3-PT HITCH, PAINT IS SHOT AND SHEET METAL IS BEAT UP AS WELL AS BAD REAR WHEEL. THANKS FOR YOUR HELP.
SHANE
ed
09-14-2001 18:47:51
 Re: WD 45 REAR WHEEL? in reply to Shane, 09-13-2001 09:49:17
For wheel, try Miller Tire, ph 419-335-7010
Richardh
09-13-2001 16:57:02
Shane;
The tractor is what ever u think it is worth 2 u, how bad u want it. I gave $450.00 4 mine WD45 all is good has one new rear tire got a good 3point 12v, had a bad PTO. Bought am D 4 $100.00 and it had the gear I neededso u can say I gave $550.00 4 mine.
As 4 the rim i don't know
Richardh
ORNGBOY
09-13-2001 17:20:26
 Re: Re: WD 45 REAR WHEEL? in reply to Richardh, 09-13-2001 16:57:02
A rim CAN cost as much as $240. A new tire @$200. A tube @$25.00. Calcium? I took it in wallet ONCE by not considering the cost of rims and tires. That is a BIG chunk of money when you have to replace them. Offer the least amount you can get away with for the WD45. I've seen em go from $500 to $2500. Good Luck!
