Old Allis
Leo
09-12-2001 19:48:19
I picked up an old Allis and have no idea of the model. Cannot find any plate for serial number. Can anyone tell me how I might be able to tell just what it is. I suspect either WD, or WC. Tractor is very heavy.
Dan
09-14-2001 11:32:51
 Re: Old Allis in reply to Leo, 09-12-2001 19:48:19
If you suspect either WC or WD. Check brakes and gear shifters. handbrakes-WC, long gear shift that comes out more from under gas tank- WC. Foot brakes and short gear shift that tends to stick straight up-WD. Electric start WC's battery case will be on front of left rear axle. WD's will be in center of tractor in front of gear shift. In any case their numbers are on rear end. WC's is on rear and middle differential pot. WD's numbers will be left of center on rear end below break inspection plate.
Duey (IA)
09-13-2001 09:45:45
Leo,
At the top of this page, click on Allis Chalmers then click on photo gallery and find what your tractor looks closest to. Then post the model and ask where to find the serial number. Once you have the serial number, you will know exactly what you have. Duey
