Allis Chalmers C 1949 positive ground?
Larry
09-09-2001 18:31:33
Helping a freind with some battery problems, and I need to know if the 6 volt system is Positive ground or negative ground. Does ground go to post by battery or underneath the battery box?
Many thanks!
Orin (NC)
09-10-2001 17:17:16
 Re: Allis Chalmers C 1949 positive ground? in reply to Larry, 09-09-2001 18:31:33
You can find a wiring diagram and other info at http://www.tractorcentral.com
Ted Seifert
09-10-2001 16:43:07
Originally grounded to the post that supports the steering column. The bolt that fastens the battery box to the post.
Ted
Phil Auten (Tx)
09-10-2001 10:53:47
Positive ground. Any good, clean spot will do for the ground, I don't know where the original connection point was. Make sure the battery cables are at least 2Ga. wire, larger is better.
Phil
steve
09-10-2001 15:26:39
 Re: Re: Allis Chalmers C 1949 positive ground? in reply to Phil Auten (Tx), 09-10-2001 10:53:47
if you hook it up backward, the generator will be toast. positive ground and negative to the starter as Phil said.
