Trying to identify a tractor
jody
09-09-2001 14:20:41
can anyone tell me where to find the serial # on a wc or a wd allis. i found a number on the frame but cant find a serial # that matches it (250334)was the #.
Phil Auten (Tx)
09-10-2001 10:50:28
 Re: trying to identify a tractor in reply to jody, 09-09-2001 14:20:41
Jody,
On a WC the S/N is in the center of the rear axle on a raised area. Tractor No will be cast in with the S/N stamped below that. The S/N will start WC followed by numbers.
On a WD, the S/N is next to the left brake housing (standing behind the tractor) very near the spring hole. The S/N will start WD followed by numbers. This may be hard to read and may require scraping off dirt/oil and or paint as some of them aren't stamped very deeply.
Phil
john
09-09-2001 19:46:01
look on the back of the rear end just a little to the left it should start with WC or WD..
