Allis G
plow
Don (Ont.)
09-08-2001 15:59:37
I came across a plow for my G and figured out how it mounts to the bracket on the front axle, but the method to lift the plow up and down has me puzzled. The tractor has a manual lift. Any advice would be appreciated. I am also looking for a sickle bar mower for the G.
den/illinois
09-09-2001 11:20:28
 Re: Allis G - plow in reply to Don (Ont.), 09-08-2001 15:59:37
There should be a short piece of flat metal call a "rocker arm extension". this piece of metal is about 2 inches wide with a half circle cut out of one end (cut-out is same diamiter as rocker arm) and the other end has a chail slot cutinto one side. This piece of metal extends the rocker arm by a few inches and allows the lift chain to be adjusted easily. There should be a chain attached to the plow on the front of the beam assembly (right behind the disc coulter bracket.
If you need more help..e-mail me.
