Allis Chalmers WD
Greg S.
09-06-2001 14:54:38
I need some help determining the serial number on the allis I just purchased. I found a number stamped on the motor that I assumed was the serial number, but it does not match any production numbers. Can anyone help with this??
The engine number found was WD 297730 PA
Brian G. NY
09-06-2001 16:12:03
 Re: Allis Chalmers WD in reply to Greg S., 09-06-2001 14:54:38
If the engine is original, you have a '51. The "tractor" serial number is located on the left rear vertical surface of the differential between the brake spring hole and the brake adjusting bolt/locknut.
Jamie
09-06-2001 15:48:08
On the back axel under the left brake adjust
