Snap coulper brackets
shawn
09-03-2001 19:56:11
The brackets that go on the 2 pt. hitch lift arms to hold a snap coupler plow keep releaseing especialy when I make turns.Is this a simple problem of weak springs or is it a indicater of a bigger problem.Would it hurt if I wired them shut.
Paul
09-04-2001 17:54:08
 Re: snap coulper brackets in reply to shawn, 09-03-2001 19:56:11
Could be bad springs or that the little tips on the hooks are worn off. I have new OEM springs if that is your problem; these seem to have more tension than the el cheapo types found in some stores. Do you have the cast or stamped metal top latches? The stamped metal latches were prone to coming unlatched. Also, could be a plow adjustment problem. But it won't hurt to wire them shut.
