WD hydralic pump
Jamie
09-03-2001 15:12:52
First thanks to those with the help on the freont steering bearing. Got apartt and everything back togeather. Now have hydralic pump problems. Running tractor, I have nothing hooked up to the pump yet as far as loader, which is still off, and the lift arms. Was misting out fluid at front nut , cone shaped, took off and tightened back down for looked as if parts were going to come out that I was not ready for. When put tractor away after another short drive it was no longer leaking there. I feel I should go through everything on the pump. Does it come apart as easy as it looks in the manual? Something a beginner like me should do? Any advice will be nice. Thanks Jamie
Tom
09-04-2001 17:50:50
 Re: WD hydralic pump in reply to Jamie, 09-03-2001 15:12:52
It isn't too hard to take the pump apart.If you do though have a manual with a good exploded view of the parts and keep them in order. You will need to get several different size O rings to put it back together if you want to do a good job. Keep everything cleaner than clean too.
David T. (MO)
09-04-2001 21:17:49
 Re: Re: WD hydralic pump in reply to Tom, 09-04-2001 17:50:50
I found that its a good idea to tack a 1x2 to your workbench slightly higher than the work surface to keep round parts from hitting the floor. Matter of fact, its a good idea to bracket the entire work area with 1x2s. Another good idea I found (the hard way) is to work the pump on several layers of newspaper. This will hopefully keep most of the oil out of your shoes. ;-)
Richard
09-03-2001 18:17:47
Jamie;
Glad 2 here that u got the front end out & in with know trouble.
Don't know anything about the pumps, but if u need one I got am extra one.
Richard
