WD Help
Bob
09-02-2001 06:57:32
Thanks guys for your help. I hope that when you mentioned that is where the oil go's you meant into the front of the govorner?? One more question, I notice a leak, (small) out of the shaft on the water pump. It drips down onto the hose so I thought at first it just needed tightening but it is the pump. Is there a kit with packing or does it need to go for a rebuild somewhere?? Thanks again, Bob
Dave in Mo
09-04-2001 09:48:48
 Re: WD Help in reply to Bob, 09-02-2001 06:57:32
Bob, has this WD sat for a long time? Mine did and leaked just like yours. Took the water pump off and looked at the seals. It's a press fit assembly and I couldn't get it apart. Put it back on the tractor and just ran it. Eventually, the leak went away, I guess as the spring loaded carbon seals reseated. I put some stop leak in the radiator to fix some pin leaks there too. So far so good. Take care where refilling your cooling system. Loosen the plug on the pump when adding the fluid to make sure the pump gets primed.
Jerry Coulter
09-02-2001 12:15:17
AC sold rebuild kits, but success was poor. The pump body needs refaced where the carbon seal rides. Best to send it out for rebuild or buy a new pump. I don't have recent info, but 4 years ago the Temco stores sold new pumps for $84.30 and Arrow rebuilts for $50.05.
