Front bearing on WD steering HELP!!
Jamie
09-01-2001 16:29:49
Want to replace front bearing in the steering. Thought would be simple. I should know better by now. Have wheels off and hub assembly. Looks from my manual that it should come out the bottom. I have the set screw out of the top gear and nothing. Went to try to get the thing to go up but I cannot get the hand start shaft out. Pin will not move I am just mushrooming the end. Been trying to get the shaft to go down no luck. What do I need to do now? HELP want to get it off jack stands ASAP for do not feel all that stable.
joe m
09-01-2001 20:47:28
 Re: Front bearing on WD steering HELP!! in reply to Jamie, 09-01-2001 16:29:49
I don't know about the rest, but I think it's alot easier to bring it out from the bottom.
There's a couple of pic of it in my album
See my photos of My WC at PhotoPoint
Richard
09-01-2001 17:59:57
Jamie;
Keep going cut the key off on the hand starting crank and remove it from the front support.
Remove cover from front suport remove set screws. Then use a suiteable puller and pull sector and key, it will all come out the bottom remember the seal in the bottom u night have 2 put some presser on 2 get it 2 drop. Make sure that the tractor is very stsble and supported goog b4 u do this. B4 u put the hand crank back in take a good drift punch and remove the pin u cut off, so when u put it back 2gether u can put a new pin in.
