WD45 PTO (Kemper)
Richard Haen
08-30-2001 14:43:27
Kemper;
I found a WD with a seazed motor, how, as u said u can take it out from the bottom? Do u have 2 splite the tractor? if not tell me how if u will, what I need 2 do>
Richard
Kemper
08-30-2001 16:22:05
 Re: WD45 PTO (Kemper) in reply to Richard Haen, 08-30-2001 14:43:27
Richard, remove the pto gearbox,then on the intermediat gear shaft there is a set screw that holds the shaft in place,take out the set screw and then you can slide the shaft towards the rear of the tractor out of the intermediate gear,you will probably have to remove the hydraulic pump also,(the shaft will hit it when you slide it back)i think there is two bearings on the shaft & a thrust washer ahead of the gear,they are tricky getting lined up to go back in.Hope this helps.
