What type fluid?
Chris
08-29-2001 21:30:51
I need to refill the power steering on my 160 after changing a hose.Looks like the guy I got it from had been using ATF. The manual calls for A-C Power fluid 106 in both the power steering and transmission. My question is can I use universal tractor fluid ? Can I mix the two (ATF and universal) or do I have to flush the whole system?
Gary
09-01-2001 14:45:01
 Re: What type fluid? in reply to Chris, 08-29-2001 21:30:51
Chris; I would drain the oil and you can use universal tractor fluid.
Phil Auten (Tx)
08-30-2001 07:13:13
Chris,
If it were me, I'd drain the system and refill it with the recommended type of fluid. ATF may be compatible, but why take a chance?
my 2�,
Phil
