HD5 ALLIS CHAMBERS DOZER
Terry
08-29-2001 08:05:34
I'M having trouble getting it to turn to right. took off check plate over brakes & mud &water was inside.Is it a wet brake & what kind of lubricant does it need? it seems to be a brake band type.Thanks for all the help I get. Terry
Terry
08-30-2001 15:13:17
 Re: HD5 ALLIS CHAMBERS DOZER in reply to Terry, 08-29-2001 08:05:34
thanks Lee! dozers are new to me. so the two outside brake compartments are dry.What about center compartment where the shaft from tranny comes thru? What kind of oil does it use if any? and how much? all you"re help is greatly appreciated! THANKS Terry
Lee Bradley
08-30-2001 10:28:04
The HD-5 used dry brakes/clutches. There is a drain plug in the bottom of that housing. Remove it drain and wash the mud/dirt out. I would run it for a few days with the top cover off to let all the water vapor escape.
