Fuel Recommendations for WD-45
Peter M. Langon
08-25-2001 18:36:38
Believe it or not, today was the first time I had to fuel up my tractor since my grandfather gave it to me last year. My question is, what is the best kind of fuel to use? I have a 1956 WD-45. I regular unleaded (87 octane) ok? Should I be using a lead additive, or any other additives? Thanks
Phil Auten (Tx)
08-28-2001 12:12:27
 Re: Fuel Recommendations for WD-45 in reply to Peter M. Langone, 08-25-2001 18:36:38
I agree with Glenn. Marvel mystery Oil will also help prevent sticking valves. Another good product for tractors, etc. that don't see a lot of use is Sta-bil. It is a fuel stabilizer that will prevent varnish build up in the fuel system and keep your equipment easy to start after sitting for long periods.
Phil
Glenn(WV)
08-25-2001 19:54:48
87 octane is fine. If you are really worried about the valves, get some Marvel Mystery Oil and mix it into the gas according to the directions on the Marvel can; it will help lubricate the valves. From everything I've read, the lead additives you can buy are not much more than snake oil. I've never used a lead additive. HTH
