Need wire diagram for 1948 WC
Black Bart
08-21-2001 18:45:38
Can anybody send me a wire diagram for a 1948 WC,
Also can I run a voltage regulator with a 12 volt system? Thanks Black Bart
Joe M
08-22-2001 18:27:43
 Re: Need wire diagram for 1948 WC in reply to Black Bart, 08-21-2001 18:45:38
Here's a copy out of my shop book, it's all I've ever seen. I think back then they took it as being too simple to go into much detail
See my photos of Tractor Friends at PhotoPoint
steve
08-22-2001 15:56:27
Im sure someone has a wiring diagram for you. What exactly do you mean a voltage regulator for 12 volt. If you wish to run a 12 volt battery on your tractor, that is o.k. The battery will work batter and not know the difference in voltage. You probably have a magnito ignition and it has nothing to do with the battery. Your only problme will be the charging system. You will need a different 12v generator, 12v alternator, or just leave the wire off and charge the battery every monday when parked in the barn. Additional questionss on the system?
