D14 HELP!
paul boullion
08-21-2001 18:12:00
I DO'NOT GET ANY FIRE AT PLUG ON MY D14 HELP!
steve
08-21-2001 18:31:50
 Re: D14 HELP! in reply to paul boullion, 08-21-2001 18:12:00
the 4 plug wires go into the distributor cap. the coil wire plugs intot he middle of the cap. take the cap off and look at the points. rotate the engine and see if the points open and close. see that the point is clean. could alos be condenser or the coil. you need to check one at a time. can probalby take the coil to NAPA and have it checked out. Is the hot wire connected to the coil cap? Do you have a kill switch or key bad?? Did it quit all of a sudden, after setting all summer, or after it was running and hot??? some of this may help narrow down the problem.
