Allis B pistons/rings questions
john
08-19-2001 21:31:00
rebuilding the Allis B, ring gap(new rings) in new 3 3/8" sleeve is .018...i would of thought new rings would have been in the .007-.017 range it this going to be alright? The new pistons are aluminum instead of cast,do they call for the same piston to sleeve clearance..... ..or what would you recommend for piston to sleeve clearance using these aluminum pistons. Seems like my manual, a 1940's vintage Thompsons calls for a rather loose fit for the pistons. Any wisdom would be appreciated.
steve
08-20-2001 20:01:01
 Re: Allis B pistons/rings questions in reply to john, 08-19-2001 21:31:00
in general terms the piston should have .004 inch diameter clearance and the rings should be .007 to .017 as you say. in reality the piston can be .006 or .008 and it will run forever, but thats out of spec. i have disassembled engnes that are .010 and they still run. ring clearance of .018 is o.k. actually up to .025 would be fine. again, i took apart an engine that was .030 overbore and had standard rings (.100 end gap) and it ran 30,000 miles until it bunt a top land on the piston. low compression on these engines is forgiving.
john
08-21-2001 03:04:24
 Re: Re: Allis B pistons/rings questions in reply to steve, 08-20-2001 20:01:01
Thanks for the info Steve. I came home with the least expensive sleeve set, i'll look for quality this time.
