WC Front tranny seal?
Jim
08-18-2001 15:02:18
I'm working on a WC for a tractor pull buddy of mine and I need help. After disassembly it looks like the front tranny seal rides on the shaft where there is spiral cut in it allowing it to leak through the spirals when not running. Can anybody set me straight with how this is supposed to be?
Joe M
08-18-2001 20:40:35
 Re: WC Front tranny seal? in reply to Jim, 08-18-2001 15:02:18
the spirals are cut over time from the pattern in the input shaft. A new seal will stop it for a while, (AGCO's is still cork) or you can hunt up a thicker rubber seal that might last longer. The spirals were made to force the oil back away from the seal when turning. Check your oil level closely, I have found if you drop the oil level just a hair it tends not to leak.
Jim
08-18-2001 20:56:17
 Re: Re: WC Front tranny seal? in reply to Joe M, 08-18-2001 20:40:35
This WC has 13.6x 38 rear tires and 4.00 x 12 fronts so it is really low in the front. Could I fill the spirals in with JB Weld to stop the leak with a new seal?
