C camshaft thrust plunger
DaveJ(WI)
08-16-2001 15:32:41
There is a lot of clearance between the thrust plunger and the cam ID. Does indicate a preblem since the spring and plunger are all that keeeps the cam oil galley full? Would installing a 5/8 "frost plug" with a.060 or.090 hole drilled in it provide enough oil for the cam gears and aid in maintaining oil pressure ? Any thoughs would be helpful. Thanks, Dave
