Brad
08-14-2001 20:19:21
I am in the process of restoring a 1945 allis WC, and I need paint codes If anyone can help. I could use the paint bought on the shelf, but have had bad luck with such previously.
Thanks for all help provided Brad
Phil Auten (Tx)
08-15-2001 05:58:10
 Re: Paint Codes in reply to Brad, 08-14-2001 20:19:21
Brad,
Besides the Ditzler DAR60080, I show the following codes for P.O. #1:
Martin-Senour paint 99L3723 or Martin-Senour 90R-3723
TISCO TP280
DuPont DULUX 008DH
DuPont 008 OR
DuPont Centari YS 074 (this seems to be the replacement for the older DuPont paints)
Hope this helps,
Phil
Butch(OH)
08-15-2001 04:29:59
PPG Ditzler DAR60080 acrylic enamel is one of several correct police approved paints for tractors like yours that should be Persian #1 If you are on a tight budget Quality Farm and Fleets Allis Orange is real close. Don't use the QFF (or any other economy paint) if the thing sits outside as it will fade before your eyes.
Brad
08-15-2001 13:40:11
 Re: Re: Paint Codes in reply to Butch(OH), 08-15-2001 04:29:59
I know about the qff paint... I have a mh 33 I painted with this, and all i can say is... NEVER AGAIN. It is ok for a maintenance finish, but not much more.
Thank you for the help,
Brad
Butch (OH)
08-15-2001 14:26:55
 Re: Re: Re: Paint Codes in reply to Brad, 08-15-2001 13:40:11
We painted a B with the QFF paint over a year ago and it looks almost as good as the day I painted it. We use the tractor, but it never sits out. Painted the plow and frame the same day. The frame sat out for a month and the paint looks ten years old. I know the tractor has been exposed to more sunlight than the plow frame over the course of a year. Go figure?
Brad
08-21-2001 20:26:31
 Re: Re: Re: Re: Paint Codes in reply to Butch (OH), 08-15-2001 14:26:55
A big problem with the qff massey red is it has a BAD tendancy to "spiderweb" and a even worse habit of taking 3 weeks to dry to the touch (even if it is cut and sprayed to their direction). I bought some paint from Tractor Supply (which I hear is the same) but it did not do it to me, just the qff.... did the same on a friend who painted his drop deck flatbed with it
