AC-C what year
I'm confused
Dana (IA)
08-11-2001 15:23:54
I have a model C that has me a bit puzzled. The tractor number shows this tractor was one of the very first model C's made. However, the engine numbers indicate a much later model (not to mention it has distributor/coil set up). My assumption is one of two things happened. The transmission was replaced or the engine was replaced. Is there any other way to determine what time frame this tractor was built? Are there any other casting numbers that would give a hint to it's year?
steve
08-12-2001 09:51:01
 Re: AC-C what year - I'm confused in reply to Dana (IA), 08-11-2001 15:23:54
As far as i know the only date coded numbers are stmped on the engine and the transmission case. I dont remomber anything on the differential or radiator that would help distinguish a year.
Junior
08-11-2001 22:04:44
My book shows the frist c made was in 1940 SER.NO 111 They was in production 11 years.Engine Model CE for the B,C,CA. But some of the B series had
Engine Model BE insted of CE
all was made by allis .Hope this helps 1940,111 to 1950,84030 serial no.
