CA charging system
Don
08-07-2001 10:47:48
When I test the generator output from the generator output terminal to the ground I find a small voltage output, about 2.5 volts. What is my problem? It's a 6 volt system. Thanks.
kent
08-07-2001 12:10:37
 Re: CA charging system in reply to Don, 08-07-2001 10:47:48
You need to run a wire from the "field" terminal on the generator to ground for the test. Then put the red lead of the voltmeter on the "armature" terminal on the generator and the other lead on ground. Grounding the field will force the generator into a full output mode. That's basically what you're doing when you pull the rate-of-charge switch out (if your tractor still has it). Don't run it on full output for a very long time but a few minutes won't hurt it.
