WD transmission clutch.
Don E. Foster
08-07-2001 10:44:29
I finally got my WD back together enough to drive it this morning!!! Been a long row to hoe. Now I am sure there is something wrong with the transmission clutch. There is no "catch" either forward or back, it just flops. I am studying the parts manual and find no spring to control the movement. There is no "feeling" at any point in the movement fore and aft. Do I have a problem?
Duey (IA)
08-07-2001 21:14:12
 Re: WD transmission clutch. in reply to Don E. Foster, 08-07-2001 10:44:29
Don, The hand clutch has a big washer, retainer and snap ring inside the assembly that gives the "snap" to the clutch. The assembly has 3 sets of shims where it is bolted together. Assuming nothing is broken, removable of an equal number of shims from each set is how the clutch is tightened up. You will have to remove the battery box etc. and cover to get to the clutch. I use a feeler gauge to check that the clutch is set evenly at all three shim sets. .020 for the two disc WD and .030 for the three disc WD45 clutch.
Duey
Tom
08-07-2001 17:48:02
You may have to remove some shifs to make it tighter. Check your manual on this. You do have a reprint of the repair manual, from King's Books don't you? Much good information.
