Ca final drive axel
tommy m
08-06-2001 07:58:35
i just pulled rim&wheel off l.h rear axe, the axel has 1/4 " end play in it.i pulled the cover cap off & everthing is tight. any one have any ideas what i should look for,before i start.shims,snap rings,etc. thanks tommy m
Dick L
08-06-2001 09:44:34
 Re: ca final drive axel in reply to tommy m, 08-06-2001 07:58:35
Take the stud out of the center of the axle that is under the cap and remove some of the shims that are under the stud. Make sure that you don't take out more than necessary and cause the bearings to bind. If you remove all the shims and you still can move the axle in and out you need to remove the axle and inspect the bearings.
tommy m
08-07-2001 03:50:49
 Re: Re: ca final drive axel in reply to Dick L, 08-06-2001 09:44:34
thanks dick l,already did that,bearings shot,going this morn.to try to locate some, thanks t.m
