WC six hole rims
BTD
08-06-2001 07:17:15
I have a '37 WC that is in my 'to be restored' area. Problem is is that right now I cannot move the tractor, I brought it home with one shredded rim in the front and no rubber to speak of. The hubs are six studded. What I need to find are some old rims I can use to support the front of the tractor and allow it to roll. My father in law is an amazing pack rat and had tons of tires and rims, mostly from old cars and trucks. Can you guys think of anything off hand that would fit the situation until time for the restoration and regular tractor rims? Thanks! -BTD
Brad
08-14-2001 19:54:11
 Re: WC six hole rims in reply to BTD, 08-06-2001 07:17:15
Rims off the rear of a old John Deere combine may work. I had 3 JD 45's, and they had 6 bolts.
steve
08-06-2001 19:02:35
I had the same idea on an old ford. I just got a couple random rims and drilled out my own holes. put 3 regular 1/2 inch bolts in each wheel to hold it to the hub. You say you have plenty of old wheels to choose from, just drill out a couple. Works fine as long as you dont plan on driving at a high rate of speed.
BTD
08-07-2001 06:09:16
 Re: Re: WC six hole rims in reply to steve, 08-06-2001 19:02:35
Thanks! I'll go rummaging through my father in laws pile o' rims. -BTD
