Oil leak-WD
Dan
08-02-2001 04:46:24
My WD has an oil seal leaking around pulley shaft on front of motor which I assume is the crankshaft. Is this difficult to replace? Can it be done without pulling radiator? Thanks for any information.
Jamie
08-02-2001 18:10:08
 Re: Oil leak-WD in reply to Dan, 08-02-2001 04:46:24
I was able to replace the oil pan gasket without removing radator. Did have to take one bolt to frame in front motor support and two bolts to engine and tap support foward to make acces easier. All I replaced was the bottom oil pan gaskets. Hope this helps.
