Hydraulic pump cylinders
Mark F
01-15-1999 13:57:44
my loader worked fine on my W.C. until I shut the tractor off. When I restarted it, I couldn't get the loader to go up when I moved the lever.I took the hose conection off at the pump and moved the lever and fluid shot out . It also shot out each plug hole on top of the cylinder. It still doesn't go up. Is there anybody that could tell me the next thing to look for?
Lee Bradley
01-16-1999 09:39:01
 Re: hydraulic pump cylinders in reply to Mark F, 01-15-1999 13:57:44
Sounds like the system is not building pressure. Two possible causes: the pressure release valve failed (broken spring or stuck open) or the pump drive failed but drag in the drive still turns the pump but slips under load.
Good Luck,
Lee Bradley
