WD45 shifting
JD Swinney
01-14-1999 19:29:44
It gets hungup in high gear. Whats the easy way to get back to N.
JOHN S.
01-29-1999 19:07:05
 Re: WD45 shifting in reply to JD Swinney, 01-14-1999 19:29:44
I had the same trouble W/ second gear. The best way I found was after taking the shifter out, have someone hold the clutch in & using about a 2' bar make the forks form a box; this is neutral. A good flashlight makes the job a lot easier, the problem is the fork is worn.
Lon
01-16-1999 18:51:53
Under the transmission lever boot is a snap you can remove. This allows you to lift the shifter lever up and out. With much patience you can relocate the lever in the gear its stuck in and move it to neutral. I assume when the trans is stuck in high the shifter lever is out of postion. Good luck.
