Allis Chamler Model B
Joe
07-30-2001 14:57:48
I just bought a (1940? AC model B) tractor and I can't get it to start every time. One day it will start the next it will not. Whether it is cold or hot it does not make a difference. I think I have a good spark and I'm getting gas to the plugs. If anyone can offer some help it would be greatly appreciated.
Duey (IA)
07-30-2001 19:53:47
 Re: Allis Chamler Model B in reply to Joe, 07-30-2001 14:57:48
Joe,
You might want to check the ign switch or wiring also, as it sounds like intermittment electrical problems. If you have a mag, remove the wire from the side post. This will eliminate any switch or wiring problems. If you have a distributor,turn the switch on and check for voltage at the distributor. If you have voltage and still no spark I would replace the points and condenser.
Duey
steve
07-30-2001 19:35:10
you think you have gas and spark. thats realy all you need. normally the gas will have a problem after running, not when starting. I would guess it is related to the spark. HOw about chekcing the spark plugs and wires, may even be time for a new set. take cover off the mag and look inside. dirty point, loose wire on the kill terminal, etc. If it is intermittent i would guess electrical.
Ken/Wa
07-30-2001 19:04:48
Spray some starting fluid in the breather. That will eliminate spark if it runs fine.
