Bad situation with an Alice WD....Help
Rich
07-30-2001 08:53:09
I need a little advise:
A neighbor lady has a WD or WD-45 it says WD 45 but the engine has a plate on the right side
so it was reengined or wrong sticker on it.
I went over there this weekend an she had water in the oil.
It had, had a water leak in the radiator and the other neighbor had run it low and refilled it while hot from the garden hose and broke the block and then he moved without telling her about the tractor, she was just sick when I pulled the head and found the bad news. She had put about 600.00 in the engine 2 years ago.
It has a Freeman loader on it and some type of pin disconnect on it with a snow plow blade on it with a BIG tilt/dump Cyl on the bucket attachment
and a two spool control.
Filled tires in very good shape tread wise but one has some type of rubber compound patch on it (?) Rims look good with a adjustable tread width.
The head was really clean with obvious new valves.
Did a Quick check with a straight edge, looked ok
As this was a running tractor most stuff is ok on it, but no 3 point though and its a Row crop front.
I told her it was probably worth more in parts than
sold as is. At this point she started crying as her husband has been dead for a few years and she is just eeking by
and has no money to fix it.
I want to help her out but can't spend tons of time doing it as I have too much of my own to deal with.
There is a tractor/threshing show coming up in a couple of weeks near here, what parts are of demand for a Alice WD/WD45 that I could take up to the show for her?
Carb, starter, manifold, lights, PTO shaft, loader. dist,
and what are reasonable prices? what else??
hood tin looks good but fenders are rusted out.
Tranny's good, is it worth anything ? it has a straight stick
Gas tank, rear end?
Trouble is I know about fords, but not much about the old alices
Any help would be appreciated.
Rich
Ray W.
07-31-2001 19:45:46
 Re: Bad situation with an Alice WD....Help in reply to Rich, 07-30-2001 08:53:09
I have a WD. I paid $200.00 for 1 USED rear tire , tube & rim last summer. The rim has adjustable tread width also. If you were close , I would be interested in the front bucket set-up. I'm not sure how they are set-up on this tractor.
Hope this helps.
Tom
08-01-2001 18:41:30
 Re: Re: Bad situation with an Alice WD....Help in reply to Ray W., 07-31-2001 19:45:46
If it has a straight shift lever it is a WD. Some WDs had curved levers but no 45s had straight ones. 45s had constant mesh gears, WDs sliding gears. It is too bad to break it up as it was a running tractor. If a engine or block could be found..... .. The serial no. is on the back of the differential, on the left side, behind the left brake on the machined area. It will say WD or 45 and then the number.
