Wd timing
dale
07-29-2001 20:16:44
how do you get the govoner gear lined up with out taking front of motor off
Duey (IA)
07-30-2001 05:49:36
 Re: wd timing in reply to dale, 07-29-2001 20:16:44
Magneto or distributor??
Duey
dale
07-30-2001 20:39:40
 Re: Re: wd timing in reply to Duey (IA), 07-30-2001 05:49:36
its a mag it woodint wind out i took the mag housing off an forgot tu mark it
Duey (IA)
07-30-2001 21:13:15
 Re: Re: Re: wd timing in reply to dale, 07-30-2001 20:39:40
Dale,
You should be able to remove the governor housing that the mag attaches to and change the timing to the cam gear. Remove the #1 sparkplug and hand crank until air comes out. Then center the fire mark in the timing hole. Remove the wire cap from the mag then install the mag/governor housing assembly with the rotor lined up with the timing lug in the cap. If you have removed the big cap just be sure the beveled tooth on the small steel gear is aligned with the "C" mark on the big fiber gear. You do NOT have to remove the front of the engine to do this. Duey
dale
07-31-2001 03:26:11
 Re: Re: Re: Re: wd timing in reply to Duey (IA), 07-30-2001 21:13:15
that did it thanks a hole bunch
