Transporting a 'B'
Tim
07-28-2001 04:54:58
When transporting a tractor on a trailer, what is best: 1. putting it in gear? 2. locking the brakes? 3. both of the above? 4. none of the above and rely on rock solid tie down chains and straps? I have a 1940 'B' that I plan on transporting regularly. Thanks in advance for the info.
Paul (Md)
07-30-2001 17:46:14
 Re: Transporting a 'B' in reply to Tim, 07-28-2001 04:54:58
You should always haul a tractor chained down with it in gear (or 'park' for newer tractors) with the brakes locked. If a chain breaks or comes loose, you will be glad you had that extra protection against unplanned unloading at highway speeds.
John (C-IL)
07-28-2001 12:35:21
Tim, If you are hauling a short distance, all of the above would be the correct answer. However, if you are hauling a longer distance I would leave the tractor in neutral as you stand to have some small movements of the crank and pistons with out the benefit of lubrication for a long period of time. John
