WD will lift arms pick up round bale? 3pt hitch
mike
07-24-2001 10:08:47
I am ready to put 3pt hitch on my wd but first i would like to know if the lift arms cylinders will handle a 1000-1200 pound round bale? also witch 3pt hitch kit is the best or witch is the best price. I have seen worksaver,saginaw,c and d hitches is there others i should look into?thanks for any help
Wayne
07-24-2001 20:38:55
 Re: WD will lift arms pick up round bale? 3pt hitch in reply to mike, 07-24-2001 10:08:47
I make a bale fork the the snap-coupler hitch. The tractor handle 1000 lb pretty good with 300 lb. counter weight on the front of the tractor.
Wayne
steve
07-24-2001 19:33:37
the tractor should have the hydraulic power. how about adding 200-300 pounds of counterweight up by the front tires, or on the side rails forward of the engine???
Mark/Ks
07-24-2001 11:23:24
I have a WD-45, and have a homemade 3-pt, but as far as lifting the bales, My WD-45 can handle the Smaller bales, (800-1000lb) bales really nicely. I tried the larger bales, but the front end would lift, and had to steer the tractor with the brakes.
Tom
07-24-2001 18:33:20
 Re: Re: WD will lift arms pick up round bale? 3pt hitch in reply to Mark/Ks, 07-24-2001 11:23:24
As a kid I used to operate a 45 with a big bog harrow on the back, when lifting the harrow and driving away it was very easy to do a very long wheelie. and you had to be carefull steering. I think the harrow weighed in the 1000 to 1200 range.
