Hey Gordon Chance, have a question
Mike
01-14-1999 11:53:00
Are you familiar with the 160 series? If so, here's the question;
Is there a common or chronic problem with them blowing a seal or gasket that causes the three point to bounce (pumps up to set point then leak down enough to pump up again at about a 1 to 2 bounce per second rate depending on implement weight)?
Yeah, I know I'm going to have to pull it apart to fix it but I'm hoping...
Gordon Chance
01-14-1999 15:32:22
 Re: Hey Gordon Chance, have a question in reply to Mike, 01-14-1999 11:53:00
Mike: Yes I have worked on the 160 model a few times but not enough to call myself an expert on 160 hydraulics. We have very few of this model in our area. My best guess as to the cause of your problem would be a leaking or blown seal on the lift cylinder piston. That would be tne area that I would look at first. Good luck. Gordon
