WD clutch
Don E. Foster
07-20-2001 15:59:26
What is the baffle and brass firtting on the WD under the inspection plate below the starter? Doesn't seem to be hooked to anything and the manual is no help!!! Thanks
Duey (IA)
07-20-2001 20:08:06
 Re: WD clutch in reply to Don E. Foster, 07-20-2001 15:59:26
Well Don, you just found one of the little traps that AC engineering created. It is a vent for the hydraulic reservoir that points directly at the foot clutch just waiting for you to overfill the hydraulic. This would happen when someone would be using a wagon hoist that was low pressure high volume would add oil to get the hoist high enough. When the hoist was lowered the fitting you found would direct the overflow oil into the the clutch!!! I removed the fitting on my WD and WD45 and plugged the hole. To provide a vent I drilled a hole and welded a pipe coupler to the inspection plate off side to miss the starter, then installed a cylinder vent. Duey
Duey (IA)
07-20-2001 20:04:58
