WD 45 SHIFTER PROBLEM GEAR SLIDES FROM NUETRAL WITHOUT SHIFING
GREG
07-20-2001 09:16:24
AFTER TRAVELING IN 3RD OR 4TH GEAR AND CLUTCH IS DEPRESSED FIRST OR SECOND (I HAVEN'T CONFIRMED WHICH)WILL SLIDE INTO GEAR AND STICK THERE. THE SHIFTER WILL MOVE TO NUETRAL AND BE ABLE TO SLIDE THE REVERSE GEAR BUT WILL NOT MOVE TO THE 1ST - 2ND SLOT OR SHIFT OUT OF GEAR. IS THERE A BALL OR PIN IN THE TOWER THAT IS TO KEEP OTHER GEARS HELD FROM SHIFTING WHEN ONE GEAR IS SHIFTED? DOES ANY ONE HAVE A DIAGRAM OF THE TOWER OR SUGGESTIONS?
