Serial Number? How old is my tractor
Clint
07-17-2001 19:05:30
The number on the right side of the engine is
WD326147PA
The number on the left side of the engine is
U-3019 38
The number on the rearend is
AM-3635-7
How old is my tractor?
Is this the original engine?
How can you tell if it is the original engine or not?
Brian G. NY
07-18-2001 06:00:14
 Re: Serial Number? How old is my tractor in reply to Clint, 07-17-2001 19:05:30
Clint, If it is the original engine, your tractor is a 1952 WD. Look up the "Tractor" Ser.# on the rear LH vertical surface of the differential below the brake cover. There is a machined area between the brake spring hole and the brake adjusting bolt/locknut where the number is stamped. I have been compiling a list of the engine vs the tractor serial numbers in an attempt to find some sort of correlation. As I understand it, engines were used in combines, road graders, stationary units, etc., so there probably is no direct correlation; only an approximation, depending on how many of the engines were used in the other applications. My late brother's '52 WD's engine # is WD326470PA and the tractor # is WD116619; putting it pretty close to yours. BTW, "PA" indicates the high compression engine meant to burn 70 octane or higher gasoline, whereas, a "KA" engine would be low compression meant to burn tractor fuel, distillate, kerosene or low octane gasoline. I would appreciate it if you would post your tractor serial number when you find it. Thanks,
Tom VT NW PA
07-17-2001 19:56:37
Clint, scroll down the first page of this forum to the WD45 question and answers and see if that helps . Then this website or the unofficial allis site has serial # listings.Also some of the guys can tell you if the numbers are factory units or replacments.Tom
Tom VT NW PA
07-17-2001 19:55:14
