Model B Oil Pump
Marv
07-16-2001 07:00:10
I just rebuilt my engine but do not seem to be getting good volume out of the oil pump. Does anyone have any ideas on this and where I can get a new pump from.
Thanks-Marv
S.AMMER
07-18-2001 17:14:19
 Re: Model B Oil Pump in reply to Marv, 07-16-2001 07:00:10
Marv I am working on a "C" and just got a new pump from AGCO, they are still available but was it ever salty. New pump $243.50 plus any state tax for your local area. But new pump on new(rebuilt) motor seems to make sense to me.
steve
07-16-2001 16:11:51
Tyler is right, the B has very little flow. You only get 10-15 psi at the filter tap. How do you inow you have low flow? Are you looking in the filter, or have line off going to the top end?? In the end, taking pump apart and sanding down the ends to be flush again is a good idea on all overhauls.
Tyler(WA)
07-16-2001 07:38:50
B models don't have "good" oil flow when they're new. Why would you expect better with a new pump?
Half kidding, of course. The 'B' model oil pump is marginal at best so you want to make sure it measures up to spec before you put it back together.
Don't "upgrade" the line to the head with a larger tube size to increase oil flow to the upper end. It will improve delivery to the head but at the expense of the oil to the mains and you'll ruin a good engine.
Dick L. can help you with bringing your oil pump up to spec. I think he had an article with some good pictures regarding that area of the 'B'. Alot can be improved by sanding the oil pump cover plate flat. The surface wares over time.
Tyler(WA)
07-16-2001 07:30:36
