Crankshaft For later WC Ac
Don
07-15-2001 20:35:22
Does anyone know where you might find a good crankshaft for a later WC AC. I know they make .040 under brgs. but has anyone herd of .060 under size. Thanks Don
Ryan - IN
07-18-2001 11:20:28
 Re: Crankshaft For later WC Ac in reply to Don, 07-15-2001 20:35:22
We just put .040 under bearings in my neighbors '37 WC, got them from AGCO.
.060 sounds awful thin, even with the limited HP these tractors put out. . .if you can't find a WC crank, a WD & WD45 crank will both fit. . all the same block, different sleeves & pistons.
We found a WD crank for $100 and all it needed was polished.
Where are you? I may be able to help some if you are near Indiana.
