WD steering
Don E. Foster
07-14-2001 10:12:34
I am restoring a WD and have found the cranking shaft very hard to push in to connect with the fan pulley to crank the engine. I have taken the shaft out with a lot of effort and find something is really chewing into the shaft. I suspect it is the gear that needs adjusting. It is a single front wheel. I cannot find anything in the manuals as to adjustment of the bearings supporting the spindle shaft. Any ideas????? Thanks
Dave in Mo
07-17-2001 04:33:25
 Re: WD steering in reply to Don E. Foster, 07-14-2001 10:12:34
My WD does the same thing. The front wheel casting does not line up with the engine. I think over a long period of time, the main channels take a set and actually bow. I took the whole front end off and found there are really no adjustments. I ended up making my own shims for the bottom of the shaft. I bet there is a huge amount of slop in your steering too. That's the result of the play in the large square key on the shaft and the casting that holds the wheel spindles.
Duey (IA)
07-15-2001 19:18:42
Don, You will have to shim the lower bearing down to allow for the shaft and gear to be lowered away from the cranking shaft. Duey
Duey (IA)
07-15-2001 19:17:49
Duey (IA)
07-15-2001 19:16:33
