WD PROBLEM
JERRY
07-13-2001 09:00:28
I HAVE A RECENTLY PURCHASED WD. AFTER GETTING IT RUNNING PROPERLY AND A FEW DAYS USE IT SEEMS TO BIND UP WHEN IT IS IN GEAR AND THE CLUTCH IS ENGAGED. WHEN OUT OF GEAR IT FREEWHEELS FINE. IT ALMOST ACTS LIKE THE BRAKES ARE LOCKING UP BUT THAT ISN'T IT. ANY IDEA'S?
Mark A
07-16-2001 10:32:26
 Re: WD PROBLEM in reply to JERRY, 07-13-2001 09:00:28
Get a John Deere!!!
Mark A
07-16-2001 10:30:22
Get a John Deere!!!
Brian G. NY
07-14-2001 06:11:42
Check to make sure your tractor is full of transmission oil. My brother's tractor did the same thing one day when he was pulling a set of drags. He had a leak and didn't check his fluid level very often. I don't know what made it "seize up" like that, but after he filled it with gear oil, it has worked fine ever since; more than 3 years. I was amazed there is apparently no serious damage!!
Brian G. NY
07-14-2001 06:10:30
Brian G. NY
07-14-2001 06:08:28
