More 6080 oil leaks
Eric D
01-12-1999 18:34:14
Thank's for submitting a follow up to my other message. The 6080 does most anything we throw at it, grind feed, loader work,and anything else it can handle. What is real annoying is when you're in a hurry and you have NO hydraulics, that means no steering, 3-point, and no hydraulics. If you open one lines coming into the pump, and turn the steering wheel, eventually the pump regains prime. If you have any suggestions, Please let me know. Thank's Eric
Gordon Chance
01-12-1999 19:53:05
 Re: more 6080 oil leaks in reply to Eric D, 01-12-1999 18:34:14
Eric: Is this a problem that shows up when you first start the tractor for the day and what kind of climate do you operate in?
Vic
03-06-1999 13:59:49
 Re: Re: more 6080 oil leaks in reply to Gordon Chance, 01-12-1999 19:53:05
The problem is probably the trans-diff, vent
located under the floorboard
Vic
03-06-1999 13:59:24
Vic
03-06-1999 13:25:28
I have a 6060 and the hyd would get jerky when it
was hot and wouldn't work at all when you next
started it. The vent on the trans had a ball in it
that make a vacume, it even would empty the front
compartment,making the diff appear over full. Eventualy making the front seal leak. The factory
rep just knocked the ball out of the vent, which
is located under cab floor
