WD quits after 30 seconds
wayne winslow
07-12-2001 09:56:34
After starting my WD it runs for 30 seconds and quits. I have all kinds of gas coming to the carb. and the sediment bulb is clean and getting all kinds of gas. When I remove the bolt in the bottom of the carb the gas does not out of the carb as much as it does does going to the carb. Is the carb. the problem or is it something else?
Ryan - IN
07-12-2001 13:03:37
 Re: WD quits after 30 seconds in reply to wayne winslow, 07-12-2001 09:56:34
Go to NAPA and get a rebuild kit, it could probably use it anyway. Completely take the carb apart and use lots of carb cleaner on all the passageways. Clean out with air compressor as well.
May want to blow out the fuel line while you are at it.
Tom Miller
07-15-2001 23:09:13
 Re: Re: WD quits after 30 seconds in reply to Ryan - IN, 07-12-2001 13:03:37
i think that all your problem is that the carb has not been gone through and the float is sticking, so blast is with some carb cleaner.
Tom Miller
07-15-2001 23:08:54
Dave Grubb
07-12-2001 12:55:44
You have probably got some dirt stuck in the float valve of the carb. You may need to disassemble the carb and back flush the valve with air or a carb cleaner. Wear some safety glasses though.
Dave Grubb
07-12-2001 12:54:56
