D14 exhaust manifold
muffler connection
LD
07-11-2001 05:17:08
I recently purchased a D14. The tractor came with a new muffler but it doesn't seem to fit into the manifold opening. The muffler seems like the right one from looking at a parts catalog. The previous owner fit it into the bracket and just butted it up to the manifold as tight as possible. The manifold connection also seems to be corroded and doesn't have a well defined opening. Is this a common problem for the D14? Do I need a new manifold or is there another fix? Any suggestions are appreciated.
Duey (IA)
07-11-2001 10:10:30
 Re: D14 exhaust manifold - muffler connection in reply to LD, 07-11-2001 05:17:08
LD,
On my "C" and "WD" I found a hardware store that used to do plumbing and talked the owner into loaning me pipe taps that I tapped threads into the manifold. I installed a 6" pipe nipple for the muffler to slip over and clamped it in place. As I remember the pipe for the "C" was a size smaller than the "WD". I also installed "D12" and "D17" oval mufflers. (Had to recut the holes in the hood.)A real solid installation. Duey
