Model B Bearings.
jeedoubleyou
07-10-2001 07:25:00
I need to get a hold of a set of main and rod bearings for an Allis Chalmers Model B from 1939.
The mains are .20 and the rods .10. If you have some let me know your prices and availability
Tyler(WA)
07-10-2001 07:59:08
 Re: Model B Bearings. in reply to jeedoubleyou, 07-10-2001 07:25:00
Most full service auto parts stores can get you these. You have to mic. the mains and rod bearings to find the right size because each engine was built a little different and one size doesn't fit all.
You'll also have to get some plastiguage and measure each bearing for proper clearance at torque. You use shims to add space between the cap and mount bolster to get the desired bearing clearance. Be patient, it takes time.
