D15 brakes
Gordon
07-09-2001 21:13:44
Ihave A D15 that has full pedal brakes that don,t stop the Tractor (1963) can anyone tell me what i need to take off to get to the brakes if i need to replace them (are the brakes wet type)
Gordon
07-13-2001 00:34:17
 Re: D15 brakes in reply to Gordon, 07-09-2001 21:13:44
Thanks for the info, I think I can handle it now
Ben
07-11-2001 08:59:43
Hi Gordon
All D series tractors seem to have the same problem. The original axle seal at the tranmission housing is made of leather. They worked well when new but after they get some age on them the seal starts to seep, letting oil migrate out onto the brake shoes. All D series tractors have dry brakes. However some are band, some are drum and some are a band disc combination. A 1963 D-15 should be the shoe type. If you still have a good amount of adjustment on your brake rods you may only have to pull the axles, change the seals and degrease the pads. Some of the original pads had a matalic type pad that does not absorb oil so a good degreasing will be all you need to do. Also check the oil level in the Transmission/rear end. It is the same resivior in that tractor. Be sure not to run the oil level higher than marked. Doing so will also contribute to oil seeping out the axle seals. Good luck.
Mark
07-10-2001 15:39:14
You must remove the rear wheel, rear fender, and
the rear axle housing from the transmission. The
brakes are on the the pinion shaft inside the axle housing. I think they are dry type but I'm
not sure. It doesn't say in my owners manual or shop manual and I haven't had mine apart yet.
Hope this helps.
