Wd45
eric
07-08-2001 20:41:16
whats the trick to get a govenor to work properly on a gas engine.
Duey (IA)
07-09-2001 05:23:21
 Re: wd45 in reply to eric, 07-08-2001 20:41:16
eric, Best guess is , you need to replace the governor weights and pins. Just a very small amount of wear in the pivot holes in the weights and on the pins will cause the governor to be very sluggish!!! Duey
David Walker
08-01-2003 22:47:23
 Re: Re: wd45 in reply to Duey (IA), 07-09-2001 05:23:21
My wd45 throttle lever is very stiff. The problem is in the governor, it won't open and shut properly. How can I fix this?
